09-24-2020
		09:28
		17:19
			LizzyFitbit
		09-24-2020
		09:28
		17:19
			LizzyFitbit
Anyone else having this issue?
When I scroll to settings, and click through to display, everything goes dim and I can barely make out the options. I want to of course adjust the brightness and how to wake the watch, but it won't let me select any of the options. You can barely make out the words on the screen in this menu screen (fine on all the others).
Just wondering if I'm missing something obvious. I have already rebooted the watch to make sure that wasn't it.
Thanks for any help!
Edit: Solved. It came with sleep mode enabled. Ooof. So I was THAT guy.
09-13-2022 22:54
09-13-2022 22:54
Try a Restart and do it several times if necessary. But first, make sure your Brightness setting is not set to Dim. That setting is reached by swiping left to Settings and Brightness is the top one.
Hope this helps
		09-16-2022
		11:53
		06:02
 Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
		09-16-2022
		11:53
		06:02
Hi there, @willjoe.
Thanks for taking the time to share the steps that worked for you. Your post is very helpful and I'm sure it'll help other members experiencing similar issues. If you have time, check out our Health & Wellness board where you can find great tips to keep achieving your goals. Have a good one! 😎
