12-08-2020
18:10
16:23
JuanFitbit
12-08-2020
18:10
16:23
JuanFitbit
Language button does nothing when I press it on my Sense. Using Pixel 4 XL. Course speech to text is completely useless. It never works. Well it did work one time for me today. One time. This watch is just buggy. It won't even change time zones on it's own.
12-11-2021 17:03
12-11-2021 17:03
It has been a year now from first reported the issue and still not fixed: Sense is a watch, if it does not show the correct time....
12-11-2021 20:07
12-16-2021 13:16
12-16-2021 13:16
Thank you for the information. That worked for me too. The massive amount of steps from the moderator didn't work. Thank you again!
02-21-2022 16:02
02-21-2022 16:02
Going to my account on Fitbit.com did the trick! Thanks! I had done everything with support (factory reset, app settings changes), but they did not direct me to my online account on Fitbit.com. Timezone was apparently "stuck" on where I had been the previous 4 days.
Fitbit support actually issued a return label to send my watch in for an exchange. Last time they did that (watch would not charge), I had to call them up and see what was going on with the replacement, as they had my Sense for almost a month. Apparently it was lost in their outbound queue. I would prefer to give them my CC and they cross ship a replacement (if one is needed) rather than this "ship it to us and when we get your watch, we'll ship a replacement to you" policy.
But in this case, no shipment needed. Yay!
Mike
03-12-2022 09:50
03-12-2022 09:50
Just came back from a business trip and had this issue. After reading all the steps everyone was going through and did the one initially from the "best answer" about changing to manual and restarting.
Turns out in my case the app settings had somehow changed itself to Manual instead of Automatic. I'm not sure if that happened due to changing the phone's settings from automatic to manual did it but at the very least, toggled it back to automatic and all's good.
I'm with y'all though, I've been wearing Fitbit since the charge HR and it's embarrassingly hilarious how bad all the sync software *continues* to be. Hopefully Google will clean it up now that they own them.
Best Answer04-26-2022 18:37
04-26-2022 18:37
So, this is the permanent fix, thank you @jandeanne , but FitBit, this should really be on by default with the option to turn off. This is creating a lot of friction for your users.
Best Answer06-30-2022 18:48
06-30-2022 18:48
What worked for me was manually resetting the time zone on the dashboard on fitbit.com. I don't know why, the site didn't open on my laptop but worked on mobile.
08-23-2022 13:38
08-23-2022 13:38
My phone is setup correctly and it’s still broken
Best Answer10-29-2022 16:42
10-29-2022 16:42
I’ve had this problem intermittently.
I found that by simply force quitting the Fitbit app on my phone (iPhone) and restarting it, the watch (Sense) changed time zones properly.
Much easier than the previously recommended steps.
11-20-2022 17:48
11-20-2022 17:48
Isn't it just sad that a $300 "smart" watch can't even change times zones. But how about that great calling function - oh wait, that doesn't work either.
Best Answer01-07-2023 23:39
01-07-2023 23:39
In my experience the answer to this lack of syncing of time zone is simply to close the app (fully, ie on an iPhone swipe up and away the app) and then reopen the app. Once reopened, press sync and now the time will synchronise.
02-16-2023 11:15
02-16-2023 11:15
I'm still having this problem after several years of the bs fitbit manual workaround. When will fitbit fix this major bug???? Even after I select automatic toggle, it will intermittently return to off.
I too am an airline pilot and this very simple issue is a big deal.
Please don't tell me it's my phone's problem as this is definitely not the case!
FIX IT
04-14-2023 08:37
04-14-2023 08:37
Cannot even find this option under coloros
Best Answer04-14-2023 09:26
04-14-2023 09:26
Hi @Melicans - this might help - How to fix the time on your watch
Best Answer04-18-2023 15:38
04-18-2023 15:38
Tried these steps. Fitbit doesn't update to correct time. What else do you have?
Best Answer04-18-2023 20:22
04-18-2023 20:22
Hi @C5Drvr - which steps did you try? Do you by chance have syncing issues? See Why won't my Fitbit device sync?
