07-12-2022
16:26
10:36
LizzyFitbit
07-12-2022
16:26
10:36
LizzyFitbit
I'm on my 4th **ahem**Bit in 4 months (2 Versa 3s and 2 Sense) and NONE of them has provided me with accurate, consistent Sleep data, which is the most important feature for me. I've spent hours on the phone with **ahem**Bit Support and have followed every recommendation they have made. Obviously, the problem is not with the watches, it's with the PROGRAMMING of the watches...something that FitBit is either unwilling or unable to correct. I average about 8 hours of sleep nightly but these watches frequently only record my sleep for 2-4 hours (usually the last several hours). I'm very disappointed!!
Hi @barryrl - just in case do you have tattoos as this can affect the heart rate sensor and have you tried wearing it on the other arm at night?
Sleep is generally something the watches are good at, so it is strange it's not working for you, also in premium there is snore detection, have you tried that? It will eat into your battery life but might show a reason for a disrupted night, as might the estimated oxygen variation.
Sleep is only measured for a minimum 3 hour period so if you don't get that amount of undisturbed sleep it might not be able to measure it.
