Sense flipping between 2 clock faces
Clock face flipping between 2 clock faces...one is not even one of mine!
Has anyone has this problem?
Thank you!
4 REPLIES 4
Go to Quick settings and turn off Always On
Swipe the watch from the left edge to the right
Make sure the bottom left one is greyed out.
The manual is here
Hello @CarolinaGirlA and welcome to the Help forum.  What is the name of the clock face you are using?  And do you use Sleep Mode?  There are some clock faces that have a very different appearance when you are in sleep mode.  It's possible that you are switching between the normal and sleep views of the same clock face.  The touch screen of the Sense/Versa 3 seems MUCH more sensitive than other Fitbit smartwatches I have used.  Users are posting that sleeves and gloves cause changes.  Another user wrote that her sleeve kept starting an exercise workout!
My clock face behaves differently from what you are experiencing if the Always On option is chosen as described in the previous post.  When I choose the Always On, my clock face is in a reduced power display, but immediately displays like normal when I raise my wrist.
Laurie | Maryland
Thanks so much! Seems to have done the trick!
THANK YOU!!! This was driving me nuts!! I don't know how it got turned on but I couldn't figure it out. Whew! Thanks again!
