01-22-2021
06:58
12:17
LizzyFitbit
01-22-2021
06:58
12:17
LizzyFitbit
The heart rate monitoring is completely off. Super disappointing and service staff just dismissed the faulty product. Really irresponsible of Fitbit.
Moderator Edit: Clarified subject and updated label
@jk2310, when referring to "service staff", are you referring to Fitbit Support? If so, did they determine the Sense to a "faulty product"? If so, it is surprising they would dismiss the issue. Have you tried repositioning the Sense on your arm to see if the HR readings improve? While exercising, I position mine about 3 fingers-width above the wrist bone and the reading is very accurate - when I compare it to the Polar Chest Strap on my elliptical, the Sense reading is always less than 10 points different from the Polar readings.
01-22-2021
12:51
18:57
01-22-2021
12:51
18:57
Hi @jk2310, welcome to the Community Forums. @USAF-Larry, it's great to see you here and thanks for your great help.
@jk2310, I'm sorry for the experience that you've had with your Sense and our Support team. I understand where you're coming from and your feedback is appreciated as it'll help us to improve our services. Because the issue persists, I've contacted our team and requested them to reopen your case so they can look into your details and provide you with further assistance. They'll get in touch with you via email, keep an eye on your inbox.
See you around.
Best AnswerOut of interest what strap do you have? Anything past the two finger mark - 5mins of exercise later it starts to slide back towards my hand making it too loose. Also I’ve been out last few times with a polar h10 strap and Apple Watch. Apple Watch was almost exactly as the strap. Fitbit was just picking random numbers out of the air. Only came close to about 10-15bmp when either I was stiffs till or walking slowly on flat. The fact that there’s quite a lot of big reviews of the sense all saying how inaccurate the sense is. And how inaccurate I’ve seen it. Tells me it’s a fault with Fitbits algorithm or hardware.
Best Answer@Bauer24 in my case, with the standard strap the watch seemed to stay in the correct position. The device is very light and the strap did quite a good job. This however didn't help with HR at all. For me, watch positioning doesn't improve anything.
Best AnswerYou’re right, It really doesn’t! my apple series 5 watch I stick it on anywhere and it’ 99% of the time matches the Polar strap. The positioning this is something I’ve only seen for Fitbit devices.
