06-11-2022
12:13
17:31
LizzyFitbit
06-11-2022
12:13
17:31
LizzyFitbit
Sense is loosing and hour my phone is 3:12, sense is 2:12
Best Answer06-11-2022 13:33
06-11-2022 13:33
The difference is always one hour or can be any number of minutes? If the first check the time zone setting in your Fitbit app.
Best Answer06-12-2022 08:14
06-12-2022 08:14
Hi, @M65488 welcome to the community, go into the Fitbit app on your mobile phone, at the today screen touch your icon in the top left corner>app settings>turn off automatic time zone>select your correct time zone>return to your "today" screen and sync (by sliding g your finger down the screen & then releasing).
If this does not correct your problem you may be experiencing a syncing issue, these articles How do Fitbit devices sync their data? & Why won't my Fitbit device sync? provide guidance and advice.
If you are still stuck, please post here again.
Cheers
Gr4ndp4 | UK
