01-20-2021
20:15
04:44
WilsonFitbit
01-20-2021
20:15
04:44
WilsonFitbit
Does anyone know what to do if the sense stops syncing? New problem that just started today:(
Best Answer01-20-2021 21:01
01-20-2021 21:01
The first, and easiest, thing to do is just wait a while. I find it often won't sink, and then will again a bit later. I think some people go to a lot of extra trouble panicking the first time a sync fails.
If I am feeling impatient, I reboot my phone.
Best Answer01-20-2021 22:46
01-20-2021 22:46
Mine stopped syncing too and it’s super annoying
Best Answer01-20-2021 23:17
01-20-2021 23:17
If phone reboot doesn't help, the easiest thing is to remove the Sense from Fitbit app and add it again. It takes 2 minutes, quite easy.
Best Answer01-21-2021 04:43
01-21-2021 04:43
Hello everyone. @Pbradley Welcome to the Community Forums! @Cardionurse It's great to see you around!
@JohnnyRow @Gusthy Thanks for your input! @Cardionurse @Pbradley If you haven't done so, I recommend following the troubleshooting steps suggested in this help article: Why won't my Fitbit device sync?
@Cardionurse I was informed that you have contacted our Customer Support Team and that a case was assigned for you. I recommend reporting this syncing difficulty as well so our team can continue assisting you. Please note that they may take a while to get back to you due to recent events affecting our operations.
See you around.
