04-18-2023
07:38
10:01
04-18-2023
07:38
10:01
Occasionally my sense will track sleep when I am not wearing it. The latest was a 16hr sleep log. Most times it is 1 to 4 hours. Is this normal?
04-23-2023 09:45
04-23-2023 09:45
Hello @TArmstrong and welcome to the Community. The green LEDs should turn off when you take your Sense, or any other Fitbit, off. Sometimes they don't because of the position the Sense is in. I've seen this happen on my Fitbits -- the emitter stays on because light is reflected off the band or another nearby object. Your Fitbit tries to analyze this totally spurious data. Your wrist isn't moving, so it gets tracked as sleep. Make sure the LEDs turn off and stay off when you take your Fitbit off.
Laurie | Maryland
04-23-2023 13:06
04-23-2023 13:06
Thanks for the reply...I had never known that so ill try and keep an eye on that when I charge my sense from now on. 😁
