01-14-2022
15:29
18:02
LizzyFitbit
01-14-2022
15:29
18:02
LizzyFitbit
I have several devices and recently I've started getting about 20 thousand steps between 3 and 4 am each night. They dissapeared a few days later. Not sure what is going on. I recently got a sense and have removed the other trackers. My sleep tracking tends to show nothing for several hours early each morning. Starting to think aliens are abducting me each night and forcing me to exercise.
01-14-2022
18:09
04:13
01-14-2022
18:09
04:13
Welcome to the forums, @nerakmac.
Thanks for sharing detailed information about this situation, and the steps tried on your own. I understand how you're feeling about getting those steps and just to confirm, do you recall if MobileTrack was set up in the Fitbit app by that time? MobileTrack is a feature that records basic stats such as steps using your phone's sensors if you don't have a Fitbit device available. However, If there was a fan or anything buzzing nearby, that might have caused you to receive incorrect steps, and interrupt the sleep logs.
Assuming this is correct, follow these steps to make sure this feature was removed:
Hope this helps.
01-19-2022 08:42
01-19-2022 08:42
Thank you for replying. I did have Mobile Track and I have now disabled it. I will let you know if that works in a couple of days. Karen
01-23-2022
14:32
09:20
01-23-2022
14:32
09:20
@nerakmac It's good to see you here again.
You're welcome, thanks to you for trying the suggestions posted above. I'm glad MobileTrack was removed from your account and if by any chance the issue persists, don't hesitate to let me know. I'll be happy to continue helping you with this matter.
Best Answer03-01-2022 13:38
03-01-2022 13:38
Did this fix your issue? I'm curious if I need to do the same.
Best Answer03-02-2022 21:32
03-02-2022 21:32
14:41
09:20
03-07-2022
14:41
09:20
Hi there, @_Jacques_ and @nerakmac.
@_Jacques_ Thanks for joining this thread and if you haven't done so, I'd also recommend the suggestions described in my previous post to get your steps tracked correctly by your watch.
@nerakmac I'm glad this got sorted out after removing the MobileTrack function and thanks for keeping us posted. I hope you can keep crushing your goals with your Sense.
