How do I remove the ones it came with? I don't like them.
Best Answerhttps://help.fitbit.com/manuals/manual_sense_en_US.pdf#page29
Top of Page 30 on how to remove clock face
Hi @midnitesongbyrd - reading your post there seems something odd.
Are you sure the watch originally came with 5 faces already installed?
Is the face you bought still one of the 5?
If you tried other faces since you got the Sense, they are saved, up to a maximum of 5 as @eezeepee says, and the standard face that comes with the watch should be one of them.
Long pressing the watch face brings up the Clocks app to switch between the faces that the watch has installed on it.
@midnitesongbyrd To remove the ones you don't want to be listed, go to them in the app, and tap "remove clock face" at the bottom. It has to be a clock face you're not currently using for the remove option to be available.
