06-27-2022 12:20
06-27-2022 12:20
So, my watch is about year old now and recently ( around 3 months) it keeps disconnecting from my phone. I've tried all the suggestions here and nothing seem to work. Unless I manually sync and reconnect the Bluetooth.
On the other hand, is anyway one else keep having extremely short battery life ? Literally 2 days and it goes from 100% to 9% or just dies altogether! Help!
Never had any of those issues with charge 3!
Best Answer06-27-2022 12:35 - edited 06-27-2022 12:38
I charged mine while I was showering last night and then noticed it had drained through the night to 0%. First time it’s happened. I charged it over night to 100% and it’s gone down to 95% in under 30 minutes. Will keep a check on your post for answers.
Best Answer06-27-2022 12:56
06-27-2022 12:56
HI @Kornelia , @Freckle13 - firstly consider addressing which features you are using, such as Snore detection or SpO2 tracker app which can use as much as 4 days battery alone.
Secondly see more in How to resolve the Major issues causing short battery life.
It is normal that the battery goes 100% to 95% in a couple of hours - the last 5% takes a long time to charge and a short time to discharge.
