07-14-2021 06:07
07-14-2021 06:07
I just received a new fitbit sense and on a three mile hike today, it dropped about 6 times. My partner has a surge and it recorded over three miles while mine only 2.8.
I previously had a surge and it almost never did this.
07-14-2021 13:07
07-14-2021 13:07
Hi @Kathyss, welcome to the community.
Are you certain the Sense lost GPS signal, as in a message appeared on the screen saying so?
The reason I ask is that all devices released after the Surge seem to measure distance using an algorithm weighted heavily on the use of the pedometer. This could at least explain the discrepancy between your husbands 3.0 miles and your 2.8 miles.
Best Answer07-14-2021 13:24
07-14-2021 13:24
I have the same problem. Firstly it takes about a minute to connect to GPS and then it drops the signal many times.
07-15-2021 11:45
07-15-2021 11:45
Best Answer07-15-2021 11:54
07-15-2021 11:54
Hopefully it was just a bug/glitch that was fixed with the factory reset. I have to say I do find my GPS on my Sense to be pretty solid, so hopefully yours will be too going forward.
Please keep us updated.
07-16-2021 13:17
07-16-2021 13:17
Okay I took the watch on another walk and this time turned on bluetooth on my phone. The watch kept the GPS signal all the way. I know the phone should not make any difference but i just wanted to confirm it wasnt somehow interfering.
Anyway the factory reset and reinstall appears to have worked.
07-16-2021 13:19
07-16-2021 13:19
I did a factory reset and reinstall and it seems to have fixed the problem. It does not make a lot of sense, since i just got it this week and had done the first install the day before i took it out walking, but it did seem to fix it.
I have used it successfully for two days, one on a hike in a fairly dense forest.
Let me know if this works for you. It does wipe out preferences you set.
07-17-2021 08:06
07-17-2021 08:06
Good to hear.
Best Answer08-25-2021 19:00
08-25-2021 19:00
Mine is the same drops more than it stays connected.
08-26-2021 01:07
08-26-2021 01:07
Hi @Kathyss
Thanks for your detailed feedback. I had the same problem since the beginning (January) and realized, after several walks, that my phone's GPS and even step counting were more accurate and consistent than my Sense's. As I was walking along streets, I could later check the distance with Google Earth.
What I did since was just switch off Sense's GPS and use just the phone's GPS. But your experience and @N8teGee 's help made me want to try again my Sense GPS, following what you did.
Thanks.
08-28-2021 02:51
08-28-2021 02:51
I found it useful to read this older thread on the same issue. Apparently, Sense's GPS reliability is an issue since the beginning. It works, but it could and should be better.
