I have had my sense for little over a year now and it has started to not charge anymore. I have tried using different USB ports as wellss as various plugs and it will not start charging. It’s now completely dead and it’s rather frustrating. Any assistance would be great. I’m a keen runner and have used Fitbits through the years.
Hi @Louie199 - this can happen and often it needs cleaning or there can be a fault with the charge cable, see instructions How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
@Louie199- did you follow the links in the instructions for cleaning, notably
We recommend that you occasionally:
And/or is one pin indented?
Yup, I’ve had fitbits for at least 5 years now and never had an issue with cleaning them or them not charging.
I will given them another thorough clean later and try again.
