In the exercise settings, you are supposed to be able to edited the auto minutes, minimum 10 mins, I can change mine but it does not save, I have cleared cache, turned on location. Also it is not picking up that I have exercised. Any help is much appreciated
Thanks
@Cinniepops, you should not be able to edit the time on an auto exercise that was recorded, only the type of exercise name can be changed. What it recorded is what it is. You can, though, manually enter an exercise and specify the time.
Best AnswerHi Larry,
If you
>tap on exercise on your dash, then
>Settings,
>tap on one of the exercise where you see the automated minutes under the exercise,
>once you tap on that you can change the minutes then save
There is also a video on you tube, my daughters saves but mine does not, minimum is 10 mins before your exercise is recognised
Hello @Cinniepops Welcome to the Community Forums! @USAF-Larry It's great to see you around and thanks for your help!
@Cinniepops Thank you for the information and for the troubleshooting steps. As you mentioned, the minimum time for auto recognized exercises is 10+. You can't lower the time.
In the meantime, please try adjusting this to 15+ and make sure that the option "Auto-recognize is set to "Active". If this continues, I suggest you to log out and back into the Fitbit App.
If your auto exercises aren't being tracked, I recommend performing a restart to your watch. Also, fore more information, I recommend visiting the following link: How do I track my activity with my Fitbit device?
Keep me posted.
