01-14-2021 11:46
01-14-2021 11:46
Hi,
I just got the sense as a Xmas present. The first couple of days when i received a phonecall i could see the ID of the caller.
It suddenly stopped doing that. I read here that it's a common problem and i tried some fixes spread around on the forum... nothing helped...
How can i fix this problem?
Best Answer01-14-2021 11:49
01-14-2021 11:49
Does the Fitbit app have permission to access your contacts? Not seen the issue on my Pixel 3 XL on Android 11 myself
Best Answer01-14-2021 11:58
01-14-2021 11:58
Yes i gave it all permissions..
It is showing sms, email, ... but when someone calls it just shows 'phone'
Best Answer01-14-2021 14:26
01-14-2021 14:26
Mi e is doing the same thing. It will not sync. It will notallow phone calls or texts
Best Answer01-15-2021 05:11
01-15-2021 05:11
Hello @Incentio @Kgermundson Welcome to the Community Forums! @CybrHwk It's great to see you around and thanks for the input!
@Incentio Thank you for the troubleshooting steps you've tried prior to posting. @Incentio @Kgermundson If you haven't done so; I would recommend setting up the notifications one more time. For instructions, please see: How do I get notifications from my phone on my Fitbit device?
On a side note, please take into consideration that in order to set up, sync, receive notifications, and take advantage of other features of your Fitbit device, you must install the Fitbit app on a compatible phone or tablet. For a list of compatible devices, please check:
Which phones and tablets can I use with my Fitbit watch or tracker?
If your devices don't appear in the list, this means your phones aren't fully supported and some features may not work appropriately. @Kgermundson for syncing, you can refer to this help site: Why won't my Fitbit device sync?
Keep me posted.
Best Answer01-15-2021 09:25
01-15-2021 09:25
I tried resetting everything and it's not working. I have a samsung S8 btw so it's compatible.
The weird thing is it worked for like a couple of days. And every other notification is working. (sms, email, ...) and when i "test call" it also shows up with test call. As ID it just shows 'phone'.
On a sidenote in the setting of my bluetooth i have 2 devices: Sense and Sense Controls. Sense controls is connected but when i open the setting of Sense controls in the bluetooth menu it wont start "Calls" .. reason cant connect to sense controls .. but it is ...
kind regards
Best Answer01-16-2021 06:25
01-16-2021 06:25
@Incentio Thanks for following the suggested troubleshooting steps!
For further assistance, I’ve created a support case on your behalf. You should receive an email from Customer support. Note that they may take a bit long to get back to you due to recent events affecting our operations.
Have a great day!
Best Answer01-19-2021 07:55
01-19-2021 07:55
Hi,
I haven't received any email how long is 'a bit long' so as to have a expectation to when they are going to contact me?
Kind regards
(I have tried fiddling with it some more .. but it's still the same. text..mail...etc phonecalls show up and i can pick up .. but the caller id is not shown .. only "phone" comes up as the ID)
Best Answer01-20-2021 04:07
01-20-2021 04:07
@Incentio Thanks for your reply!
I got in contact with our Support Team and they should be contacting you soon. Please keep an eye on your inbox since you should receive an email from them.
Have a nice day!
