11-06-2020
21:15
16:20
DavideFitbit
11-06-2020
21:15
16:20
DavideFitbit
my Sense does not count steps like it should have tried to turn in off and on and still doesn't and is worse in serten areas
Moderator edit: format
11-07-2020
16:19
07:58
11-07-2020
16:19
07:58
Hi @lizzysparks, welcome to the Fitbit Community forums.
Thank you for sharing that you've been having trouble with your Sense not tracking your steps accurately.
Before considering other options, could you please provide a few extra details about what you've been experiencing? Is this happening with specific activities like driving, running? Or does this happen with regular use of the watch? Let me know why you feel the watch is not counting steps like it should.
Please keep me posted.
08:19
16:45
DavideFitbit
02-18-2021
08:19
16:45
DavideFitbit
My Fitbit Sense isn't tracking steps properly either. After a 50 minute treadmill walk, usually 5000 steps, I'm at 1870 steps!
02-18-2021
08:32
16:46
DavideFitbit
02-18-2021
08:32
16:46
DavideFitbit
Me too! It started with my Fitbit Charge 2 and thought it was giving out because it was so old. so I upgraded and it still doing that
02-19-2021
08:20
07:58
02-19-2021
08:20
07:58
Hi @LaHuera, and welcome to the Community forums @Kim95mann.
Thank you for sharing that you've been having the same inconvenience with your Sense watch.
Before considering other options, please make sure that you've tried the restart procedure as described in this article.
In the meantime, you can find more useful information about the accuracy of Fitbit devices here.
Hope this helps.
10:02
08:46
DavideFitbit
02-21-2021
10:02
08:46
DavideFitbit
Kim, mine isn’t counting steps also!!!
this is very agitating.......I waffle between my Ionic, the Sense and the Blaze and now I'm past the 45 day return policy. The Ionic is a jewel! the first time the Sense didn't count all my steps, I panicked and tucked it away because I couldn't get an explanation through my own search. I donned the Sense today to give the Ionic a rest and lo' and behold, it didn't count my steps, almost 4K!!! I checked all possible avenues to rectify the problem but to no avail. I'll wait to call support tomorrow.
02-24-2021
08:46
07:57
02-24-2021
08:46
07:57
Hi @TheSwig, welcome to the Community forums.
Thank you for sharing your feedback and that you've been experiencing the same problem with your Fitbit Sense.
Since you already tried the troubleshooting steps mentioned earlier, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
I'll be around if you have further questions.
09:05
16:52
DavideFitbit
02-24-2021
09:05
16:52
DavideFitbit
So today, instead of not tracking my steps, my Sense is indicating that after my 47 minute treadmill walk at 2 miles per hour on elevation 3, I've walked I've 57K steps?
02-27-2021
16:51
07:57
02-27-2021
16:51
07:57
@Kim95mann thank you for your reply.
If you already tried the restart procedure mentioned earlier, make sure to chat with us online or give us a call for further assistance with this. Click here to get connected.
Have a great day.
Best Answer04-23-2022 22:52
04-23-2022 22:52
I just got Sense and I used it and my old Inspire clipped to my hip and when Inspire logged 10k steps, Sense is still not 7k steps yet. Thats a big discrepancy.
04-24-2022 19:39
04-24-2022 19:39
I am having this issue as well, every hour tells me I need to walk my 250 steps and I know I’ve already done way more than that. I also walk around the room looking at my watch and noticed the steps are not counting as I take my steps. I’ve rebooted the watch, I removed it from my phone and reconnected it, I’ve killed the app. Maybe use this time for a warranty return?
10:11
07:57
04-29-2022
10:11
07:57
@gcsuarez @beachbrum Thank you for sharing that you've been having the same inconvenience with your Sense watch.
If you haven't done so already, please make sure that you've tried the steps mentioned here earlier. If you continue to experience the same inconvenience, please make sure to get in touch with the Customer Support team for further assistance with this so they can provide you with the next steps. Click here to get connected.
Thanks again for sharing all this information and your feedback. Our team is always working to enhance your experience and your feedback is a big part of that process.
See you around.
10:56
11:26
DavideFitbit
04-29-2022
10:56
11:26
DavideFitbit
My Fitbit Sense is counting steps but my Fitbit app stopped showing my steps, I tried to log off and on but it isn't helping. I also shut down my Fitbit but it also didn't help, any recommendations?
11:26
07:56
05-05-2022
11:26
07:56
Hi, welcome to the Fitbit Community forums, @MarioDIFiglia.
Thank you for sharing that you've been experiencing a similar problem with your app not showing the steps tracked by your Sense watch and for confirming that you already tried a few troubleshooting steps.
If you're still having trouble with the app not showing you the correct information, please try the following:
Hope this helps, I'll be around.
Best Answer05-06-2022 09:41
05-06-2022 09:41
07:39
07:58
05-12-2022
07:39
07:58
@MarioDIFiglia Thank you for your reply and for confirming that you already tried all the steps suggested. I'm sorry for the confusion, I've updated my last post with the correct device.
If you're having this problem only when using the Sense watch and not when you're using the Charge 4, it seems this could be related to a problem to sync your data between your Sense and the Fitbit app.
In addition to the steps suggested, let me know if you already tried all the steps listed here to resolve syncing problems, and make sure to check the compatibility requirements listed here and to keep the Fitbit app updated to the latest version available.
I'll be around.
Best Answer08-08-2022 15:27
08-08-2022 15:27
About two days ago my Sense starting having issues tracking steps. I did the most recent update which took about 20 min last night. This morning it worked fine but now it's not tracking steps again. It is charged and blue tooth is on. GPS is working but not counting steps.
Best Answer08-14-2022 12:42
08-14-2022 12:42
My sense is showing too many steps. Early morning showed almost 3k steps. No way. I restarted the sense and the app.
07:26
07:58
09-07-2022
07:26
07:58
Welcome to the Fitbit Community forums, @Gotx6432.
Thanks for confirming that you've been having the same inconvenience with your Sense watch.
Before considering other options, could you please confirm if you already tried all the steps mentioned here earlier? In addition, you can find more important information about the accuracy of Fitbit devices here.
@NanaDonna I've been informed that you already contacted the Customer Support team for further assistance with this. In this case, they will let you know how to proceed.
See you around.
Best Answer07-11-2023 07:51
07-11-2023 07:51
I just sat on chat support and still could not get heart rate working. They sent email stating it does not meet criteria for warranty. I no longer have a fit bit - I only have a watch with steps. No o2 no sleeping stats and no heart rate. I purchased September last year.
