08-13-2021
11:13
15:15
SilviaFitbit
08-13-2021
11:13
15:15
SilviaFitbit
This is the main use for thus watch.... checked all setting. Probel stared mid day Wednesday. Checked all settings. The watch is receiving the notification, it just doesn't vibrate anymore. Extremely frustrating!!!
Best Answer08-13-2021 12:02 - edited 08-13-2021 12:07
When you say checked all settings……
Did you swipe left on the watch twice, then tap settings, then swipe up to “vibration and audio”.
Tap and make sure vibration is marked light or strong?
Another thing to check which was advised per Marrefitbit is:
Please note when you turn on the do not disturb, quiet hours, or driving mode setting on your phone, your Fitbit device receives notifications but won’t alert you.
If you have an Android phone, you can set your Fitbit device to always send you notifications:
Best Answer08-13-2021 12:38
08-13-2021 12:38
Best Answer08-13-2021 15:19
08-13-2021 15:19
@Clove6060 Thanks for the instructions shared.
@Lraaa Welcome to the Fitbit Community. I appreciate the troubleshooting and the settings checked prior to posting.
I see where your frustration is coming from. Let's confirm that your notifications are set to "On" in the power tray. If they are not set to "On" turn them on and try again. May I know if your Sense is vibrating for other things such as alarms or reaching your main goal?
Hope this helps.
