07-09-2022
21:21
07:20
07-09-2022
21:21
07:20
Hi @Cecifer - did you try to place the watch on charge. If no display of charge comes up or it doesn't restart then it's most likely not charging, often the cable is faulty or the watch needs cleaning more thoroughly.
See more details in How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
Best AnswerHi, @Cecifer, welcome, have you tried restarting your "Sense"? Squeeze the side button for about 20 seconds until the Fitbit logo appears and release. After about 35 seconds it should restart.
Let us know how you get on.
Cheers
Gr4ndp4 | UK
Best AnswerHi, @Cecifer, if you are not able to make any progress with your new charging cable talk to "Customer Support" Use the Chat facility or phone for a prompt response.
Cheers
Gr4ndp4 | UK
