07-31-2021
05:45
05:52
WilsonFitbit
07-31-2021
05:45
05:52
WilsonFitbit
I'm connected to Wi-Fi on my sense but when I go to clock faces or media it won't open because it says not connected to internet no matter what Wi-Fi network it's connected to. If tried restarting sense and phone, disconnect Bluetooth, impair and repair. Deleting and reinstalling app, deleting the sense on the app and re setting it up. Please help
07-31-2021
05:58
10:13
07-31-2021
05:58
10:13
Hello @Brozum01. Welcome to the community forums!
Thank you for the detailed information and for the troubleshooting steps you've tried. At this time, I'd recommend checking if your Wi-Fi network appears under Wi-Fi Settings in the Fitbit app. If not, please manually add the network in the Fitbit App by following the instructions below:
For more information, I recommend visiting this help article: Why won't my Fitbit watch connect to Wi-Fi?
Hope this helps.
Best AnswerYes.in the app under wifi settings it says connected to the network. But when I open the clock faces or music screen in the app it says (oops looked like your not connected to a network)
It's not a watch problem.
Clock faces, if you can get them in the Fitbit App are transferred to the watch over Bluetooth.
It is more likely your phone is using a VPN connection or your phone has security software not allowing Fitbit Access to internet.
Best AnswerAs for WiFi on your tracker, the Sense needs to be plugged in and charging for WiFi to be turned on.
05:55
10:12
08-06-2021
05:55
10:12
@Brozum01 Thank you for your reply. @Guy_, @Rich_Laue Great to see you around and thanks for your input.
@Brozum01 I appreciate the additional information you provided. In this case, if the inconvenience still persists or if you need further assistance, I'd recommend contacting our Support Team. Note that you can contact them through chat or over the phone, but phone wait times have been longer than normal, so I recommend initiating a chat. Click here to get connected.
See you around.
