12-26-2020
09:27
04:29
12-26-2020
09:27
04:29
My new Sense does not display time and other details when I turn my wrist to look at it. Why is that and how do I fix it? I have seen there is an option for full time low light display of time. I followed the directions but it does not work. Please someone help
12-26-2020 09:52
12-26-2020 09:52
Hi @Commodore - It sounds like your sense may be in Do Not Disturb or Sleep Mode. If you press the button (indentation, really) at the left or if you give the screen a quick double tap, does the screen wake up? If yes, please try this:
Please let us know if this resolves your issue.
12-26-2020 09:52
12-26-2020 09:52
12-26-2020 14:37
12-26-2020 14:37
12-26-2020 16:10
01-31-2021 16:18
01-31-2021 16:18
My husbands sense looks right. But still it doesn’t turn on when he turns his wrist. He’s not in dnd mode, and ive set it to turn on with motion and button Is there a way to change the sensitivity for motion?... thanks
12-15-2021 13:24
12-15-2021 13:24
worked for me too. Thanks
05-03-2022 16:43
05-03-2022 16:43
Thanks! It worked!! 😁
08-11-2022 08:43
08-11-2022 08:43
Finally. My fitbit sense is working perfectly. Thank you so much
08-12-2022 11:50
08-12-2022 11:50
Thanks, this worked for my sense.
