06-04-2024
16:16
03:49
06-04-2024
16:16
03:49
The face popped of and I do not know how to line up the inside to make it work again help
Hi @Carlapro - if it is under warranty it can be replaced, if not and it has become completely detached detached it will have to be properly reconnected and glued.
If it is still attached (and working) it should go back with the display showing correctly and the button on the left. A bit of sealant to hold in place will be needed but never get it wet.
A phone repair shop can probably assist you even though it is not a phone as they are used to opening and closing products.
Best AnswerThank you. I think I might be able to fix it. I m found yo take it apart with a tiny drew driver. I see where it has to be reattached. Thank you fir your response. It will help if I can't fix it.
