Cannot find option to disable Snore Detect on Sense
Hi. How can I disable Snore Detect? The option is not available in Sleep Settings on the app.
4 REPLIES 4
Here is where it is supposed to be, at least.
Thanks. The option is not there.
Hi @jokl - in principle if the option is not there it is not enabled and cannot be enabled. But it is possible if you were previously a premium user (necessary to use it) and are no longer one that it got left on.
Hi there, @jokl@JohnnyRow and @Guy_ Thanks for stopping by to help our member.
@jokl I understand your concern and appreciate your efforts in trying the suggestions shared here. Because the option isn't appearing I contacted our Support team on your behalf; however, it seems that you already got in touch with them. Your case is in good hands and I'm sure they'll continue helping you with this matter, so please keep an open communication with them.
