05-06-2021
08:02
12:23
LizzyFitbit
05-06-2021
08:02
12:23
LizzyFitbit
When in settings display mode the screen goes very dark
Best Answer05-06-2021 11:02
05-06-2021 11:02
Go to Quick Settings - On the watch swipe left edge to right and
Make sure Do not disturb and Sleep icons are greyed out.
12:28
10:23
05-07-2021
12:28
10:23
Hi @bazzlar. Welcome on board. @Guy_ Thanks for your great help.
@bazzlar Just to confirm, what do you mean by settings display mode? In addition to @Guy_'s suggestions, I'd recommend changing the brightness level to see if that helps. To do this, can do this, open the Settings app, tap on Display, and adjust the screen's brightness to either Normal or Max. Let me know how it goes.
Hope this helps.
Best Answer05-08-2021 04:24
05-08-2021 04:24
When I go into the settings display screen my scrren goes very dark so I can't see the display settings to change them.
Best Answer05-08-2021 04:31
05-10-2021
12:04
10:23
05-10-2021
12:04
10:23
Hi @bazzlar. Welcome to the Community Forums. @Guy_ It's good to see you again.
@bazzlar Thanks for trying the suggestions posted above. Because your Sense screen is going very dark, let me recommend restarting your watch to refresh its performance. Once this is done, check one more time if the Sleep Mode is turned off and adjust the screen's brightness to see how it goes.
Hope this helps.
