10-07-2023
01:23
06:50
10-07-2023
01:23
06:50
Hi my sense is frozen on the logo screen. Tried restarting, resetting, nothing works. Any ideas or has it died?
Hi there, @Jen4321. Thanks for stopping by in the Fitbit Community Forums and trying to troubleshoot the issue with your Sense before reaching out.
If you haven't done so yet, please try the steps below:
If you can't get started with your Sense, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If you continue having difficulties to update your Fitbit device, see Why can't I update my Fitbit device?
Best AnswerSame here. I have followed all the above steps several times. Nothing. Mine is only 1 yr old!
Try a Factory Reset: Press and hold the left "button" for 8 seconds, release, press and hold again for 10 seconds, release, press and hold for 10 seconds and release. In this process you will feel 2 shorts vibration and 1 longer that means it is factory resetting. You will need to do the setup and paring from fresh. Good luck.
That doesn't even work when it's stuck on logo, I've tried 4x and nothing I've restarted phone (shouldn't have to) 3x. I've had this thing on charger all day.
Add me to the list. Mine just stopped 18hrs ago at last sync.
Logo is stuck on the watch face.
Have read so many suggestions to fix and none work.
So many of the Sense watches crashing almost all at once and there are no solutions
Same here, stuck on logo for days now. Nothing has worked.if your device is older than a year, there's no help other than a 25% discount on a new device. That's what was emailed to me from fitbit's warranty dept who was suppose to call me.
Spoke to soon. I did the factory reset. Went through the set-up steps, connected to wifi, download and install but started looping again. There's a communication issue between the devise and my phone.
Best AnswerI followed your steps and a red x popped up. I went through the set-up process. It connected to my phone and wifi. The download finished but the installment failed and it started looping again. Sooo disappointed.
