11-14-2020
12:00
13:25
LizzyFitbit
11-14-2020
12:00
13:25
LizzyFitbit
For some reason, the time on my sense is running 10 min behind. I was finally able to sync with the app but the time is still running behind and I don't know how to correct it. Any ideas?
11-14-2020 12:07
11-14-2020 12:07
Hi @andromeda1967 generally what seems to work in your case is to set the tracker to the wrong timezone, sync, then the correct timezone.
11-14-2020 13:08
11-14-2020 13:08
i will give it a try
11-15-2020 13:48
11-15-2020 13:48
Hi @andromeda1967. Welcome, it's great to have you on board. @Rich_Laue, thanks for stopping by and sharing your help.
@andromeda1967, I'm sorry that your Sense is showing the incorrect time. It's odd this is happening even though you're syncing it and my best advice is to follow the suggestions posted by @Rich_Laue. If by any chance that post is helpful to your inquiry, mark it as the Best Answer to help other members experiencing similar issues.
Keep me posted!
