01-18-2021
11:04
09:05
WilsonFitbit
01-18-2021
11:04
09:05
WilsonFitbit
My silent alarm does not go off on my fitbit sense and I'm not sure why? I have it set as a reocurring alarm for work everyday, and it has gone off once out of 3 possible days!
Best AnswerNot sure if this helps however I have a recurring alarm that does wake me up every morning. I have looked at the alarm app on the watch and the days the alarm is set to go off is in yellow and those days where the alarm is not set in white.
if I click on the alarm, on is highlighted in yellow and off white and each day the alarm is required is ticked.
Best AnswerI've just had a look at mine again, and on the alarm list the days to go off are set to white, and the days i don't want it to go off are black. When in that particular alarm setting the days are all ticked to go off! Do you think this is right or is it because they aren't yellow on the alarm
Best AnswerThis is what my alarm looks like. Monday, Tuesday and Thursday are set for on and Wednesday, Friday etc. Off.
Best AnswerYeah that's what I have too! The only thing I thought was could it be to do eith syncing? Although I'm not sure why that would impact it!
Hello @HarrietM28 Welcome to the Community Forums! @Basandy It's good to see you around and thanks for your input!
@HarrietM28 as @Basandy suggested, please try to remove and re-add the alarm to see if that works. For instructions, please see:
How do I manage alarms on my Fitbit device?
If there is any syncing inconvenience, you may also review: Why won't my Fitbit device sync?
Keep me posted.
