07-11-2021
23:40
06:15
07-11-2021
23:40
06:15
My stats widgets (swipe up) have disappeared. When I swipe up it shows a blank (black) screen.
01-03-2022 09:04
01-03-2022 09:04
Happened again, all of a sudden. Again, the "reboot" fixed it. But I am increasingly inclined to return this device before the Jan 31 deadline and revert to my Charge3, in the hopes that Fitbit someday releases a version of the Sense that actually works consistently.
01-09-2022
12:56
02:46
01-09-2022
12:56
02:46
@floridawalk It's good to see you again.
Thanks for keeping me posted, and the steps tried on your own. I'm sorry you've had this experience with the Sense. Every feedback is provided to our team to improve our devices, services and overall environment, and yours will definitely be taken into consideration. About your watch, you can try contacting our Support team one more time to receive further assistance. Please click here to get connected with them via chat or phone.
01-10-2022 06:04
01-10-2022 06:04
01-11-2022
10:25
02:44
01-11-2022
10:25
02:44
Hi there, @floridawalk.
You're welcome, I'm glad you had a good experience with our Support team. Your feedback is also appreciated and please know it'll help us to improve our products, as well as our services.
Best Answer01-30-2022 08:08
01-30-2022 08:08
I am having the same problem as others: My stats widgets (swipe up) have disappeared. When I swipe up it shows a blank (black) screen.
I have had my Sense for less than a month and this is the 2nd time this has happened. I could have sworn that I finally found a box to check to always show the stats for today. Is there a box that should be checked? I have tried the recommended solutions and unfortunately it did not work. Is there any new advice to resolve this issue?
01-30-2022 08:16
01-30-2022 08:16
02-03-2022
16:31
02:48
02-03-2022
16:31
02:48
Hi there, @Blessingtoyou and @floridawalk.
Thanks for letting me know about our watches and the steps tried on your own. I understand how you're feeling as those troubleshooting steps shouldn't be performed regularly on your Sense. Your feedback is truly appreciated and please know these comments won't be taken for granted.
Even though you've tried contacting our Support team before, I'd recommend getting in touch with them one more time if this issue persists. That way, they can evaluate your options and see what can be done to bring you back on track. They're available via chat and phone, just click here to get connected with them.
Best Answer02-03-2022 17:23
02-03-2022 17:23
This morning I decided to try the reboot again for my Sense and it worked! My stats for the widget are now there! 😀
But, after a few hours of the reboot, I received the "need to sync" message for the weather. I did go into my Fitbit app and sync for the weather. I can't help but wonder if the weather function triggered the widgets to disappear since it appears the need to sync is once or twice a day.
Thank you LizzyFitbit!
02-03-2022 17:37
02-03-2022 17:37
02-03-2022 18:11
02-03-2022 18:11
Wow! I assumed the you-must-sync for the weather was a normal function for it to update. I should know better than to assume anything! I am not sure if it matters, but I am using the clock face called "Glance". If I continue having this issue I will reach out to the developer via the app to see if there is any connection there.
Thank you floridawalk!
02-06-2022
18:00
03:36
02-06-2022
18:00
03:36
Thanks for sharing your thoughts about this situation, as well as your efforts while troubleshooting your watches. Please note certain clock faces and apps require to constantly sync your watch to the Fitbit app, either manually or in the background. With that in mind, please forget your Sense from the Bluetooth settings, force quit the Fitbit app, open the Fitbit app one more time and pull down on the screen to force a manual sync.
@Blessingtoyou I was checking the clock face you mentioned and it seems to be created by a 3rd party developer. If the rest of the apps and features are working well, I'd also recommend contacting the developer so they can provide you with more information. Usually their contact details can be found in the clock face description in the Fitbit app.
Best Answer05-07-2022 08:57
05-07-2022 08:57
I’ve just got the Sense and this happened to me. The restart worked for me perfectly.
Thanks for the advice. 👍🏻
05-24-2022
11:54
12:38
05-24-2022
11:54
12:38
Hi there, @jsleem1.
You're welcome! I'm glad the restart worked for you and I hope you can keep enjoying the experience with your Sense. By the way, let me invite you to visit our Health & Wellness board where you can make new friends and start your own topics. Happy stepping! 😎
