06-05-2024
04:18
05:10
06-05-2024
04:18
05:10
My Fitbit Sense heart rate monitor has stopped working. I haven't done anything to cause this myself. It worked up until two days ago. I've had this Fitbit for about two years which makes me suspicious this could be planned obsolescence.
Hi there, @stephbetro. Welcome to the Fitbit Community Forums. I'm sorry to hear that your Sense has stopped tracking your heart rate data. I understand your concern, I will do my best to help you with this!
As a first approach, I would recommend you to check this article to know what factors can affect heart rate and also some tips to fix your heart rate reading. Additionally, please double check that you're wearing your Sense properly.
Best AnswerI have been wearing FitBit products for about 10 years now, and this is the first time this has happened. I have made no changes to the device settings or how I wear it. Can you please suggest other ways to actually fix the issue?
@stephbetro Thanks for getting back and the details provided.
As our last resort, I'd recommend performing a factory reset on your Sense. Important: Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
With the above being said, please sync your Sense and then, proceed with the steps below in the order listed:
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Best AnswerI've had the same issue. Sence stopped tracking heart rate and sleep. Have done a factory reset and uninstalled and reinstalled everything. Took 4 hours. No change.
I'm in the same boat, uninstall app, factory reset wouldn't sync. Now it won't detect heart rate or sleep. I can't find the solution either.
Hi,
I'm not going to do that based on the below responses. The only difference there has been, is the app updated. Then the heart rate stopped working. So I think this is planned obsolescence, and really don't trust a factory reset will help. Are there any bug fixes?
Thanks.
Best AnswerThanks for the info! Unfortunately mine was 2 years old as of mid-May, and this problem of course comes up now. Hence why I'm thinking this is planned obsolescence.
Thanks again!
