01-24-2023
17:17
04:05
01-24-2023
17:17
04:05
My Fitbit Sense stopped working after only 5 months of use, can I return/exchange it?
Thanks
Hi @Tooootall - your watch has a minimum warranty of a year so can be replaced where you bought it.
However if it was working fine and stopped responding the issue may only be with the charge cable or charging.
See help on that How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
In any case you can still chat anytime via the Fitbit App, click profile photo, Help & support, Contact Customer support.
Hi there, @Tooootall. Welcome to the Community Forums.
To better assist you, would you mind sharing more details about the issue with your Sense? Is it not charging, syncing, responding, turning on?
In the meantime, please take into consideration the tips and recommendations provided by @Guy_.
Look forward to hearing from you.
