09-21-2021
16:48
18:52
LizzyFitbit
09-21-2021
16:48
18:52
LizzyFitbit
When using these features if I open the Fitbit app on my phone the watch will stop tracking my activity and then reboot the watch. This is a repeatable bug and happens every time I try it. A very serious flaw in this programming
Best Answer@jdigs56 could you give more info?
Are you using the Walk, Run, Hike feature on the tracker, or the ones found in the fitbit app on the phone.
When using these features on the tracker, there isn't any live connection with the fitbit app.
18:45
07:50
09-23-2021
18:45
07:50
@Rich_Laue Thank you for your help.
@jdigs56 Nice to see you around. Thank you for your information and report.
Just to avoid any further confusions please confirm the following:
You start to record a hike, walk or jog on the watch and while the recording is running, you start your phone and the record stops, and you return to the clock face?
This only happens, when recording a hike, walk or jog, with no other activity or use of an in watch app, right?
Does this situation happens when the Fitbit app is on or not on your iPhone?
Do you try to use the GPS on the Sense?
Please, make sure, that you have the latest Fitbit app installed.
Restart your Sense: How do I restart my Fitbit device?
Restart your phone (off/on)
See you around.
18:38
07:50
09-26-2021
18:38
07:50
@jdigs56 Thank you for your reply and confirmation.
Our team has been informed and they will be monitoring the situation and work on a solution for it.
Should I receive further information, I'll be glad to inform you over here.
Hope it gets solved soon.
See you around.
