08-26-2021
10:36
11:22
08-26-2021
10:36
11:22
Fitbit Sense, touchscreen, side button don't work. Will register a double tap but cannot swipe up down or sideways. Side button doesn't work at all? Any suggestion on how to fix.
Best Answer08-26-2021 11:23
08-26-2021 11:23
Hi there, @Vekter. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Sense.
Please restart your watch as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
08-26-2021 11:23
Hope that helps.
Best Answer08-31-2021 16:22
08-31-2021 16:22
Tried to restart but touchscreen will not swipe. Call support they are sending a replacement.
Best Answer08-31-2021 16:47 - edited 08-19-2023 07:00
@Vekter Awesome! I'm glad to hear that our Support Team helped you with this matter. 🙂
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
