09-30-2020
08:46
11:31
LizzyFitbit
09-30-2020
08:46
11:31
LizzyFitbit
How do I make the stair counter work properly? My new Sense is congratulating me on all the stairs I've taken when all I've done is walk on flat ground. Thanks!
Best Answer09-30-2020 09:04
09-30-2020 09:04
Hi, @LieslDiesel Fitbits calculate “stairs” using a built in altimeter which detects very subtle changes in air pressure to determine if your elevation has increased by 10 feet. While this usually works pretty consistently in detecting actual stairs and hills, its sensitvity means it is easily affected by changes in air pressure from other causes. This means that if the weather is windy, or there is a storm blowing in “stairs” may be counted even on flat ground. The stair count can also be affected by a strong draft (I get lots when the train is coming through the tunnels in the London Underground) or even if someon slams a door.
For that reason many people take the stair count feature as a nice extra, but not overly concern themselves about exact accuracy. Stair counts are not included in Fitbit’s calorie calculations
09-30-2020 09:04
09-30-2020 09:04
09-30-2020 10:05
09-30-2020 10:05
Thank you - this helps!
Best Answer11-09-2020 02:58
11-09-2020 02:58
Do it looks like the best answer is to turn it off or ignore it. I live in a bungalow and frequently am told I’ve done 15 flights in a day
Best Answer11-09-2020 07:42
11-09-2020 07:42
@NigelCheltenhamSame thing will happen in a bungalow as well so it is still the correct answer
Wendy | CA | Moto G6 Android
11-16-2020 08:08
11-16-2020 08:08
Can you explain to me why it was working fine for the first 2 months of use and now its way off ? (by like +100 floors/day) I dont get it.
