12-29-2020 17:01
12-29-2020 17:01
just received my Sense. When I attempt to adjust brightness it is so dim I can hardly see it AND it will not allow me to touch screen to make any changes. I have re set twice no luck anyone else having issue?
12-30-2020 10:38 - edited 12-30-2020 18:59
@SunsetRunner @janem21 open settings app on your watch (gear cog icon) and scroll down to display. Set brightness there to normal or higher. Also, check if the night mode is not enabled. On the main screen of the watch swipe right to see quick settings. Make sure the night mode (middle top icon) is disabled. If that doesn't help try factory reset (Settings app on your Fitbit>About).
12-29-2020 19:07
12-29-2020 19:07
I'm having the same problem.
12-30-2020 10:43
12-30-2020 10:43
Best Answer12-30-2020 11:28
12-30-2020 16:50
12-30-2020 16:50
Thanks so much for your help! Problem solved 😁
12-30-2020 19:00
12-30-2020 19:00
@janem21 awesome 👍🏻 Happy New Year!🎉
Best Answer01-18-2021 14:19
01-18-2021 14:19
So happy ... changing night mode worked!
Best Answer01-18-2021 14:31
01-18-2021 14:31
Best Answer01-18-2021 17:53
01-18-2021 17:53
@sueraymond21 Glad we could help! 😄
Best Answer05-07-2021 00:28
05-07-2021 00:28
Thanks especially the reminder to check for night mode in the quick settings - that was the issue I had with. It being able to see the screen. 👍
Best Answer03-30-2022 12:08
03-30-2022 12:08
Thank you! It somehow got into night mode!
