12-30-2020 17:33
12-30-2020 17:33
I am very frustrated with the Sense. It does not always synch automatically with my Samsung phone. I reboot it by pressing and holding the button but that doesn't work consistently either. I am spending way too much time trying to get this thing to do this one basic function. If I shut down from settings will I lose my data? Thanks for any help available.
12-30-2020 19:05
12-30-2020 19:05
@ShereeGold no, shutdown will not erase the data as they're stored in sense memory.
Best Answer12-31-2020 05:48
12-31-2020 05:48
I had the same issue when I first got it. I set it to charge, uninstalled it, installed it and then I was able to reboot it. Your data will definitely not be lost. Hope this helps!
Best Answer12-31-2020 06:47
12-31-2020 06:47
Try these sync tips.
Best Answer04-14-2021 16:14
04-14-2021 16:14
When I hold the button as instructed I get a message saying “set up wallet-you have no cards yet in your wallet set up now”.
Is this similar to what you were getting?
Best Answer04-14-2021 16:30
04-14-2021 16:30
Best Answer04-15-2021 10:38
04-15-2021 10:38
@Sharz1 and @ShereeGold it does work. You need to hold the button for at least 10 seconds as the restart instructions explain.
Best Answer04-15-2021 11:44
04-15-2021 11:44
I've tried it numerous times for more than 10 seconds. It does not function correctly on my device. I am not the only person with this issue. It will start with the push of the button but rarely will it shut down that way.
I've had many folks try it on my Sense to insure it wasn't operator error. It is not.
04-15-2021 14:15
04-15-2021 14:15
Have achieved it once, all other times it presents a message about adding cards in wallet. This is not the only issue I have with this Fitbit. Two bought same day same place and this ones a dud!
Best Answer04-15-2021 20:44
04-15-2021 20:44
The only way to shut the Sense down is through the Settings/About menu
