Sense will not sync AGAIN!
Once again despite using the supposed fixes my Sense will not sync this morning! I guess I workout again without it!
5 REPLIES 5
You can use your watch to measure things and it will keep the information for up to a week between syncs.
I presume you restart both phone and watch when it doesn't sync. and try this
In the phone Fitbit App
On the main Today tab
Pull down to initiate a refresh
If the popup progress bar has a syncing line that succeeds then it is syncing
Then also
Click on profile photo [top left]
Device photo [middle left]
Sync -
See when last synced
Try refresh by touching circle
it should say "a moment ago"
If it doesn't try the procedure again, it may take several goes.
Tried it all repeatedly. It syncs for a few days and the same problem
starts again!
Frustration, disappointed, and yes anger abounds!
Ah!
Did you also do this if you have an Android phone?
On the phone check battery optimizations
[the options may be different in your version]
  • First go to Settings > Apps & Notification > Special app access
  • Click on Battery optimization
  • Now press the drop down menu [...] and select “All Apps
  • Click on Bluetooth and then select “Don’t optimize
  • Same with Fitbit
  • Next go to Settings > Apps  > Fitbit > Storage
  • Clear cache [not data]
  • Force stop the Fitbit app
@Irish57 have you tried the help tips for sync issues.
I also have a few more things here
@Guy_ all trackers store 7 days of detail data and then up to 23 more days of daily totals.
Most trackers have limited memory for exercise data so it is possible not to get 7 days of recorded exercises saved.
No Android but thank you! It finally synced after repeated efforts in fixes and hours later. So far okay today!
