10-10-2020
		05:54
		17:04
			DavideFitbit
		10-10-2020
		05:54
		17:04
			DavideFitbit
Hi everyone, I don't have a Twitter and it seems like that's the only way to contact customer support so I'm coming here instead. I have tried multiple outlets, charging blocks, and USB connections to get my Sense to charge and it will not. It did slow charge the other week but now, even when the charging screen pops up, it loses battery.
I just plugged it in at 9% (I've been trying to charge it since 27% yesterday), the charging screen popped up, and when it warned me it was slow-charging, it was down to 8%. No matter where I plug it in, I get a warning that it is slow-charging but then it has inevitably lost battery by the time I return to it.
I've tried for days to get it to charge and it's incredibly frustrating. I have read other forum posts and tried all that is recommended.
How do I contact customer support directly? Thanks in advance.
12-29-2020 09:44
                                          Community Moderator Alumni are previous members of the Moderation Team, which ensures conversations are friendly, factual, and on-topic. Moderators are here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              12-29-2020 09:44
Welcome to the Fitbit Community forums @nathanm66.
Thank you for confirming that you're having the same inconvenience with your Fitbit Sense.
I've gone ahead and sent your information to the Customer Support team for further assistance with this, so you should be getting a reply soon.
Let me know if you have further questions.
		18:23
		10:26
			DavideFitbit
		12-29-2020
		18:23
		10:26
			DavideFitbit
Hi, was your issue resolved? Was it the cable that was faulty?
Thanks @DavideFitbit. I have one observation that you can send to the support group - When I tried to charge it soon after the first day, I laid it on a metal surface. I later noticed in the instructions that we should not lay the charger on a metal surface. Is it possible I ruined the charging cable?
 Best Answer12-30-2020 07:21
12-30-2020 07:21
 Best Answer12-30-2020 10:21
                              12-30-2020 10:21
Thank you for sharing this additional information @nathanm66, I've proceeded to send all these details to the Customer Support team so they can further investigate this. I recommend that you continue the communication with them so they can let you know how to proceed.
 Best Answer12-30-2020 13:42
12-30-2020 13:42
Hey, how long did it take to get your replacement? It sounds like some are waiting a while!
Random question ....did you take the straps off? The email they sent to me makes it sounds like I should be removing the straps before sending lol
 Best Answer12-31-2020 16:17
12-31-2020 16:17
 Best Answer01-01-2021 04:44
                              01-02-2021 06:40
01-02-2021 06:40
I have been making note of how long the battery lasts and how long it is taking to charge my Fitbit Sense which is about 1 1/2 months old. I have turned off just about everything, I only use it for time, date and steps/exercise, heart rate, sleep. I am also using the GPS. Payments, notifications, phone & music options are turned off. I am using the watch face called "Clean Stats" by Hanseware. I have tried to get it down to as basic a settings as I can to conserve battery life. I do not turn the watch off unless I need to do an update. The SPO2 has never worked on this watch and I don 't know why, it did on my Iconic.
I am using the USB3 port on my computer or I use a 1 Amp USB wall plug also. I have found as I did on my Iconic that 2.1 amps causes a lot of issues. The average battery life (from about 100% down to 20%) has been 6 days. The average charge time (from 20% battery to 100%) has been 1 1/2 hours using my USB3 computer port or my 1 AMP USB wall plug. This has been about the average battery life and time to charge since I got the watch. I see others having battery issues so I just wanted to post what I am getting in terms of battery life and charge times and how my watch is set up to see if that might help you.
At this point I believe using a 1 amp USB wall plug charge works the best as well as USB via PC. I believe that charging over 1 amp cause issues as it did with my Iconic.
Basically I have found that the Sense battery life lasts about 1 1/2 days longer than the Iconic and charges about 1 hour faster at 1 AMP or via USB 3
I am still bewildered as to pop up that claims that the watch can charge faster by using another outlet. Fitbit has given no direction regarding what the power requirements are for fast charging? Can someone from Fitbit please give some info/power requirements for a USB plug on this mysterious pop-up?
01-23-2021 02:32
01-23-2021 02:32
I've had the same trouble with charging. I think it's the 4 little silver charging points on the back. They get dead skin or possiibly cream residue from hand cream or skin cream. I get a needle and pick it out, then it charges fine. Although this is a very bad design flaw for quite an expensive watch.
01-29-2021 22:57
01-29-2021 22:57
Mine has done the same thing...This happened to me with the ionic a few times and I was hopeful it would have been fixed with the sense....no such luck it would appear!
 Best Answer04-09-2021 19:06
04-09-2021 19:06
I just bought the Fitbit Sense today. It will not charge... I wish I had been aware of the problems before... It is garbage and I'll return it tomorrow.
 Best Answer04-10-2021 12:12
04-10-2021 12:12
 Best Answer04-19-2021 17:23
04-19-2021 17:23
Thank you for your post. I was about to box it up and send it back. I tried your trick and it worked!. Thx.
 Best Answer04-19-2021 20:16
04-19-2021 20:16
@BluebelleNY wrote:Thank you for your post. I was about to box it up and send it back. I tried your trick and it worked!. Thx.
Hi, I would like to know which trick you are referring to, as I would like to try something that has worked for someone else.
I have tried all the things that I have seen here or other places on the first one that I had to send back to fitbit.
And the new second one that got here just a couple of days ago - I was able to charge this only once - I could not tell for sure as it was during the process of being set up and it might have come charged up
04-20-2021 01:05
04-20-2021 01:05
Me too and trying to get support from company who makes them is like trying to fly to the moon by flapping my wings. Thanks for the community to help us waste our money trying to keep these gadgets working!
 Best Answer04-20-2021 02:32
04-20-2021 02:32
04-21-2021 17:31
04-21-2021 17:31
I am having the same problem. It does not charge. I have read the sense watch has poor ratings fue to charging difficulties. I am getting tired of it.
 Best Answer04-21-2021 18:26
04-21-2021 18:26
 Best Answer04-21-2021 19:45
04-21-2021 19:45
I took a paperclip and cleaned out the 4 contact holes that the charger clicks into. I clicked the charger on and it started charging right away.
 Best Answer04-21-2021 20:08
04-21-2021 20:08
