12-14-2021
05:00
14:13
12-14-2021
05:00
14:13
Sense was at 79% charge 6 hours ago. Now dead and won’t charge. I purchased it 75 days ago.
Hi @GiJenn84 - your watch could just have a flat battery. To verify if the watch doesn't start when charging from a computer port.
If the terminals are clean and it is not charging it could be a faulty charge cable - to make sure carefully check the 4 pins are equally prominent and properly located.
It's quite a common issue if you look in the forums.
If it's under warranty you can contact Fitbit Support directly. They should send you a replacement one.
Also reachable via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
You can also buy them online. if you want a more robust one and are prepared to wait, click photo.
