Sense won't charge
I bout a Sense in May.  Love it, but now it will not charge and is drained to 0%.  I swapped out the usb box, and have tried everything.  Nothing seems to work.  Has anyone experienced this?  is there a fix?  the retailer said it was past return date, but is there a warranty?  Who can I call?  Thx
1 REPLY 1
Hi @gesc45
If the terminals are clean it would seem you have a faulty charge cable - to make sure carefully check the 4 pins are equally prominent and properly located.
It's quite a common issue if you look in the forums.
If it's under warranty you can contact Fitbit Support directly. They should send you a replacement one.
Also reachable via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
You can also buy them online. if you want a more robust one and are prepared to wait, click photo.
