01-01-2022
15:37
13:49
LizzyFitbit
01-01-2022
15:37
13:49
LizzyFitbit
My sense won't charge.
Best Answer01-01-2022 15:48
01-01-2022 15:48
Hi @Square1974 - Please try using a different outlet to see if that’s the problem. You can find troubleshooting tips here.
01-01-2022 20:16
01-01-2022 20:16
Hi @Square1974 - It could also be dirty contacts or a faulty charge cable. See here
01-05-2022 03:59
01-05-2022 03:59
Hi, I contacted Fitbit they are replacing the whole think because is under warranty but I think is the charge cable. Thank you
01-05-2022 05:23
01-05-2022 05:23
@Square1974 - if you got to keep the old watch you will be able to verify that it was the charge cable.
