06-14-2023
13:36
08:05
06-14-2023
13:36
08:05
My FitBit Sense won't turn on. I have tried How Do I Clean my Fitbit and buying a new charging cable and using different outlets.
I have been using it regularly since buying it at the end of 2021. It is out of warrenty but hoping FitBit would help. I really liked using it.
Best Answer06-14-2023 16:14
06-14-2023 16:14
Same here. It was after the update last week.
Best Answer06-14-2023 20:24 - edited 06-14-2023 20:28
Hi @ak45657 - was there any problem with it before it won't turn on?
After leaving on charge for an hour, hold the button for 10 seconds till it vibrates and the logo appears, hopefully.
If that doesn't work check the charge cables very carefully. How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
Also check if it is syncing in the Fitbit App, to determine if there is a screen fault or it is just not charging.
06-14-2023 20:25
06-14-2023 20:25
Hi @Lifestooshort - what update did you receive last week? There haven't been any new firmware announcements recently?
