09-28-2023
07:36
08:16
09-28-2023
07:36
08:16
From last week my Sense Fitbit is not charging... In 4 years I use same magnetic charger. The watch is full descharged . Please help .
Lucian
09-28-2023 08:19
09-28-2023 08:19
Hi there, @LucianBv. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Sense.
If you haven't done so yet, please see Why isn't my Fitbit device's battery charging?
09-28-2023 12:30
09-28-2023 12:30
Check the 4 pins on your charger they have been known to get stuck
09-29-2023 16:28
09-29-2023 16:28
How do you unstick them? I had a problem like this a year ago & I got similar advice, but I can't fix it now. They have a new charger, is it worth buying?
09-29-2023 23:13
09-29-2023 23:13
Hi @GinLi - if your watch is under warranty you can get a replacement cable free or just buy one online.
See Tips when using the Sense or Versa 3 charging cable this might avoid it happening again.
09-30-2023 02:06
09-30-2023 02:06
Thank you very much. It finally charged my watch! I have been trying for over a month.
09-30-2023 03:35
09-30-2023 03:35
I clean mine try unplugging charger then take a q-tip and some rubbing alcohol and clean all prongs then let dry for at least 10 minutes then try it.
