12-19-2021
15:49
12:00
LizzyFitbit
12-19-2021
15:49
12:00
LizzyFitbit
Since the last update Sense does not lock when removed.
Hi there, @Lakeeffect.
Thanks for letting us know about your Sense and just to confirm, do you mean that you're not required to enter the PIN each time you put your watch on your wrist? Have you checked if the Enabled setting is still selected?
If you haven't done so, please give a try to the following steps:
Hope this helps.
16:34
10:09
12-24-2021
16:34
10:09
@Lakeeffect It's good to see you again.
Thanks for confirming that the Device Lock setting is enabled. In this case, I'd suggest the troubleshooting steps described in my previous post to see how your Sense respond. If the issue persists, don't hesitate to let me know so I can continue helping you with this matter.
