02-02-2022 23:00
02-02-2022 23:00
My sense suddenly stopped opening some of the apps — specifically, the alarm and settings apps. And that means I can’t factory reset! Restarting does nothing other than get me out of the frozen apps. Help!
Best Answer02-03-2022 08:03
02-03-2022 08:03
Hi, @ChrissyBu, welcome to the community, have you been able to sync your "Sense" with the Fitbit app on your phone? If you have not these articles may help How do Fitbit devices sync their data? and Why won't my Fitbit device sync? I apologise if you have already looked at this aspect. Allowing you have tried restarting (from the clock screen swipe left to & touch "settings"> swipe up to "Shut down" and touch "yes". wait a few minutes and restart by holding the side button until the logo appears & release) I suggest you talk to "Customer Support" here. I recommend you use the chat facility or phone for a prompt response. I hope this helps.
Cheers
Gr4ndp4 | UK
02-03-2022 08:09
02-03-2022 08:09
Yeah, it syncs fine. Records everything fine. I can't use settings to shut down because it won't open settings - just starts to, then gets stuck on the little cog. I end up having to force restart (holding down the button until the logo appears) each time.
I just talked to customer support like you suggested, and they're replacing it. Apparently it's just broke!
Best Answer02-03-2022 08:23
02-03-2022 08:23
@ChrissyBu I know you're getting a replacement but if you want to try, there is a way to factory reset without the touch screen:
