I've used fitbit devices for 5 years, but my current sense is by far the worst. I'm most interested in sleep related data and it does not reliably report it or 'health metric'. Will work for 2-3 days then not work for a week or so. If check position on wrist etc. Either hardware is defective or software is buggy!
No longer useful to me. Hope is it software and they fix it soon!
Best AnswerHi, @75goats, welcome, you may be interested in this article How do I track my sleep with my Fitbit device? I apologise if you have seen it before.
You will see there have been many developments over the last 5 years, I hope this helps.
Cheers
Gr4ndp4 | UK
Best AnswerThanks for the attempt, but I've seen that page and am pretty certain 'operator error' is not the issue. I've used fitbit devices pretty continuously and this Sense is the first device that has been unreliable.
Best AnswerHi, @75goats , thanks for the update, I can only suggest you try "Customer Support" here. I recommend you use the phone or the chat facility for a prompt response.
Sorry, I cant offer more help.
Cheers
Gr4ndp4 | UK
Best AnswerI did chat with support last December when this problem first appeared. It was 'escalated' but ended with "We’re aware of it and are working to identify a resolution as quickly as possible."
Nothing since then and it is still not working so I'm frustrated..
I do plan to try chat again later today.
Best AnswerI have the exact same problem mine records me sleeping while I'm awake so my metrics say I've slept 14 hours a night which isn't true its also stopped showing spo2 in my metrics yet its on my clock face fitbit support are useless they have no answers except watch out for update
