08-19-2022 23:49
08-19-2022 23:49
I have tried the whole 'turn Bluetooth off, turn phone off, start phone again in 1-2 minutes, turn Sense off, turn it back on' thing more times than I can count now. It will find the Sense, give a 4 digit code, I enter it and then it just won't connect.
So, I'm out of ideas at this point.
00:13
10:06
08-20-2022
00:13
10:06
HI @Dmaubuch - have you tried to logout of the app [swipe off and on Android clear the storage cache and force stop it] then restart the phone to make sure it is working correctly and ensure location is set on, and try "+ Set up a Device" again.
You can always chat via the Fitbit App, click profile photo, Help & Support, Contact Customer Support, if that doesn't work.
08-20-2022 01:01
08-20-2022 01:01
Yep. Tried all of that as well.
08-20-2022 01:21
08-20-2022 01:21
Even tried uninstalling the app and reinstalling...nope. It sometimes goes as far as giving me a code...but after that - zip zero nada.
01:27
10:06
08-20-2022
01:27
10:06
@Dmaubuch - strange as it seems this may help verify the watch is able to do Bluetooth properly by using a location finder. Its not foolproof though due to the different version of Bluetooth.
What should I do if I lose my Fitbit device?
Try customer support.
Best Answer08-20-2022 07:55
08-20-2022 07:55
@Dmaubuch it may be time to contact support.
08-21-2022 13:11
08-21-2022 13:11
I finally fixed it with a factory reset. Hated losing all of my data, but nothing else was working.
It is now back up and running.
Thanks to both you and Guy for your tips and for trying to help! I appreciate it!
