02-09-2022 05:59 - last edited on 02-10-2022 17:48 by LizzyFitbit
I have been very dissatisfied with the new Sense watch I received as a gift in December 2021.
The notifications for text messages has stopped working. Tried all the fixes and nothing works.
My Sense keep dropping the Bluetooth connections, whish is frustrating.
When I swipe left, there appears to be a glitch where the battery life and I add icon flicker.
I contacted support via chat, was told this was being escalated and have not heard a peep.
I may be returning this watch and trying another brand. 😞
Moderator Edit: Clarified subject and updated label
02-11-2022 06:35
02-09-2022 06:09
02-09-2022 06:09
I know iOS and Android apps might be different but do you have an option for "Text Messages" and to be able to select which messaging app you want?
I have it for WhatApp as I use that more often than my regular text messages app.
Mods don't like this recommendation, I don't get why because it's a go-to for pretty much all electronic devices that can, but have you tried a factory reset? You've tried everything else, you might as well do that.
02-09-2022 06:14
02-09-2022 06:14
When I check the notifications applications that I can allow, there is no Messages ICON listed in my FITBIT app.
02-09-2022 06:23
02-09-2022 06:23
@jbyrne So to clarify, you don't see "Text Messages" option like in my screenshot? I'm not talking about in the "App notifications" where it lists all the apps you have on your phone.
02-09-2022 06:28
02-09-2022 06:28
No the TEXT Messages option is there and it is turned on . Up until this weekend it was working fine .
02-09-2022 08:10
02-09-2022 08:10
And only text notifications are the ones that you're missing? Have you tried deleting your Sense and adding it again? That fixes my connection issues usually.
02-09-2022 08:13
02-09-2022 08:13
Ye I have tried that as well.
02-09-2022 08:15
02-09-2022 08:15
Yeah just go for a factory reset. Yeah nothing to lose at this point.
02-10-2022 18:00
02-10-2022 18:00
Hi there, @jbyrne. @eezeepee Thanks for stopping by to help our member.
@jbyrne Thanks for the details provided, and the steps tried prior to posting. I'm sorry you're having this experience and I truly appreciate your feedback. Because you already have a case created, I went ahead to review your details and it seems they've sent you an email with further assistance. Instead of doing the factory reset, I'd recommend keeping an open communication with our Support team so they can provide you with further assistance.
See you around.
02-11-2022 06:09
02-11-2022 06:09
This issue has been fixed, so my case can be closed.
02-11-2022 06:28
02-11-2022 06:28
@jbyrne Oh that's great. What ended up being the solution?
02-11-2022 06:35
02-11-2022 06:35
Restarting phone an fitbit multiple times .
02-13-2022 16:32 - last edited on 02-24-2024 03:39 by MarreFitbit
Hi there, @jbyrne and @eezeepee.
@jbyrne Thanks for keeping me posted, and sharing the steps that worked for you. I'm glad your Sense is receiving your notifications correctly and I'll mark your post as the "Best Answer" to help other members experiencing similar issues.
By the way, let me invite you to visit the Health & Wellness board where you can create your own topics, make new friends, and find great tips as well as encouragement to reach your goals.
Have a good one! 😊
