01-31-2025
15:18
09:25
01-31-2025
15:18
09:25
There is no data when I scroll below the clockface on my Sense. Just a black screen. When I scroll back up I get back to the clockface.
I can scroll right and see the apps.
I can scroll left and see %charge and the other icons,
I can scroll up and see ""clear all" and "missed call"
I used to be able to scroll down and the first thing was temperature.
How can I fix this?
Hi @stanhilliard - the widgets (Weather and others) should appear if they have been enabled, did you keep scrolling and you may see MANAGE to reenable them, if not there may be an OS corruption that a restart of the watch may cure.
If not rather than doing a factory reset which can destroy the watch and meaning setting it up from scratch (if it's even possible if you live in the EEA) try some work arounds.
A better clock face may avoid scrolling altogether and in conjunction with moving the weather app to the first app position or assigning it to button long press or double press etc. are some options.
I did not do anything to the Sense but ignored it for the past 5 hours while I did other things. I just checked again and I can scroll down to temperature and all the other apps below it. It apparently just fixed itself.
Thanks @stanhilliard for the feedback, glad it's working again.
