I commute to everyone mostly by walking, and every time I walk somewhere my Sense vibrates even after disabling the auto detection in all the exercises. Is there a way to disable this vibration as it is super annoying.
Also, is there a way to disable the 10000 steps vibration notification as well?
Thanks
Hi @itesta - look in your exercise tile in the Fitbit App to see if your walks are registering.
If so, go into the walk exercise app on the watch and swipe up to see the options, and disable any special things, like laps.
Also check vibration is not coming from a clock face by changing clock face and verify which shortcuts are assigned, in case you are getting accidental button presses.
Lastly set your steps goal to 99,000, then you won't reach that goal, unless you are walking all day, in which case it might be time for a rest!
