Hey everyone!! Hoping you can help! My hubby was sweet enough to by me a Sense for Christmas. But it’s driving me bonkers!
It’s won’t sync my sleep score to the clock face, and it won’t sync my mindfulness or stress management back to my phone.
I have reset Bluetooth and wifi I’ve restarted phone and watch several times!
help! This was a pricey buy for it not to work!
@RBeastall In your case as it works after rebooting, it may be a power saving issue on the phone. If either Bluetooth or Fitbit are being optimized that might cause the problem. Try turning off the optimization.
Also check Sync setup and troubleshooting
Let me know if that helps, thanks.
Right!? Don’t understand my old one never had an issue. I’ve tried everything with no luck so far.
Do you keep the Fitbit app active all the time? If its closed you will mostly likely lose the connection.
Can you also check the following settings please
On your iPhone Tap on settings. Device Care Battery Fitbit, Put app to sleep - is it off? |
On your iPhone Tap on settings. Privacy. Location Services Fitbit, is it Always.? |
