05-21-2021 03:57
05-21-2021 03:57
Seems myself and a lot of others are having problems with the Sense not syncing! I have done everything that troubleshooting suggests it worked once and stopped straight after! Also I have just learnt that certain features don’t work in Australia!!! The whole reason I bought the sense was because of those features. A response from Fitbit would be great and one that doesn’t just say try the troubleshooting options, they DON’T fix this syncing issue!!🤬
Best Answer05-21-2021 07:53
05-21-2021 07:53
Hi LenaO
I just spent about 30 mins on the phone with Fitbit and they had me to factory reset the watch and delete it from the app. I have an iOS device if that makes any difference. It seems to be syncing now! I will continue to monitor throughout the day to ensure that it continues to sync without any issues.
05-21-2021 16:45
05-21-2021 16:45
Hi Andrea, I’m on IOS too. I will give that a try. Doesn’t change the fact the Fitbit is advertised with certain features and they don’t work in some countries! Thanks for your reply @SunsetRunner
Best Answer05-21-2021 21:23
05-21-2021 21:23
Factory reset worked!! 🤞 it keeps working! Thanks!
Best Answer05-31-2021 03:52
05-31-2021 03:52
@LenaO My watch is back to not working again 😫
Best Answer05-31-2021 04:34
05-31-2021 04:34
Have you done the troubleshooting yet? factory reset? Does it work afterwards?
Best Answer05-31-2021 04:39
05-31-2021 04:39
@lablover55 I have done everything. Sadly I am having no luck. I reached out to Fitbit this morning and they are sending a replacement. I hope that resolves the issue because it seem to have started with the last update.
Best Answer05-31-2021 04:51
05-31-2021 04:51
Yeah, that last update was a humdinger.
05-31-2021 16:58
05-31-2021 16:58
